Fishindaddy
- Sep 5, 2014
- 1
I recently removed the lower unit from my 1990 Mercury 25HP 2-Stroke outboard to replace the impeller. It was definitely the first time this had been done to this motor. After re-installing the lower unit, the reverse lock hook assembly will not disengage to allow me to raise the motor. I followed the hook up into the cowl and it looks like the shift rod should go through the top hook in order for it to raise the latch when it is put into forward gear.
Is this assumption correct? Do I remove the lower unit again and when re-installing, make sure the hook goes around the rod, or is my issue something different? All the parts diagrams I have found show the hook and the shift rod/linkage on different diagrams. None showing how they go together.
Any help would be greatly appreciated. I have already been through the remove and reinstall process three times due to forgetting washers or bushings etc.
