50 HP Merc 500 Not running right need help
bthomsen
I have a 1974 Merc 500 50 HP that I just had the fuel pump and the carbs rebuilt. I just got the boat and have never had it in the water before this so I'm not sure of how it ran before I got it. The engine Idles good but when I put it in the water when I try to apply throttle it does not gain any RPM's. The boat just sits at idle. The compression and spark are both good. The boat will speed up if I physically turn the distributor myself and engaging the carbs. I have a couple ideas but I figured instead of guessing I would actually ask for advice for once.
Redwing4900
Throttles hooked up correctly? I don't mean to offend you, but it could happen. Also are the throttle cables functional. It seems like a simple solution should be the answer here.
When you turn the distributor are you in neutral or in gear in the water? If the motor revs up when you turn the distributor while in gear, in the water, the throttle cables or linkage are suspects. If the motor revs up in neutral, when you turn the distributor, it is a non-test.
Remove the wrap cowl and advance the throttle and see what the distributor does.
bthomsen
Sorry it's been awhile but after further investigation it turned out that somehow during the drive to the lake the throttle cables came loose. All is well and the motor runs great. Thank you everyone for the input.
GA_Boater
Thank for the follow up, bt. It doesn't happen enough. :thumb:
