bassboy416
- Jul 9, 2013
- 79
Mercury 1150.... honestly not sure of the year the serial says it doesn't exist when i look it up the rectifier says 73 on it, but I have always thought it was a 74. I bought this from a guy who said he took it a mechanic every year and was a reliable boat. Ever since I've had it, it has been nothing but problems. PROBLEMS: 1)difficult as hell to start *solution(always have to pump the hell out of the bubble use choke and advance throttle in nuetral for first start) 2) never had any hole shot. It would run great and smoothe but when towing a wakeboarder or going from idle in gear to full throttle would die (had to be eased into full throttle). 3) kept eating batteries (all of the wires from guages to stator) so we replaced all wires, stator, and rectifier.... Once we replaced rectifier, it wouldn't idle. We changed timing so that mark on pulley was 1/2 tooth left of the mark it is supposed to line up with. It ran with better hole shot for 4 hours and then died on the water. Now won't run above half throttle... checked compression today.. .EVERY cylinder was unable to hold pressure meaning that whatever reading I got the pressure would go down to zero very quickly on the guage (checked guage on a dirtbike that was recently rebuilt and guage held at 170psi on the bike). CYLINDER 1= One pull with pull cord and no spark plugs 30 psi and down to zero in less than 1 second) CYLINDERS 2-6 compression in one pull with a pull cord was 60 psi and quickly dropped to zero.... I am trying to decide if I should replace this motor with a new unit, try and fix this myself with no experience, call the whole ($2000 investment) boat a loss and junk it, or try and transfer the chrysler 120 hp 1209hd I have off my tahiti and junk my tahiti. chris 1956 help me! what the hell do I do now?
