I just bought a new 20' Bennington pontoon and it came with a brand new 2014 60hp Mercury Bigfoot (4 stroke EFI). Yesterday was the first day out with the boat and we just could not keep it running. It started right up and idled fine at the boat launch and traveled fine on way out of the marina for about 400 yards at roughly 2,000 RPM's as soon as we got out into the lake I increased throttle to about 2500 RPM's and the motor stalled shortly after. I waited a few minutes and it started back up and ran ok at 2000 RPM's for about a minute and stalled again. I hit the primer bulb a couple times but the bulb was almost collapsed. I messed with it for a minute and got it to expand back out again. The motor started and we took off I then went up to 3000 RPM's to see what would happen and the motor stalled within about 5 seconds and the primer bulb was almost completed collapsed almost like it was sucked in. I then tried to restart immediately and it would not start. Hit the primer bulb a couple more times and waited and it ran fine at 2000 RPM's for about a minute and it stalled again. I took the gas cap off to see if it was vapor locked and got the same results. This went on all day and never did get it to run right - ended up getting a tow back in. Pretty sure the motor is not getting gas for some reason and not sure why especially with it being fuel injected. Any ideas would be greatly appreciated
