leblancjoel
- Aug 12, 2014
- 11
I need to know how to remove the rods that go through the tilt trim cylinders, both at top and bottom. I have attached photos to help. I do not want to damage the threads in these pins/rods, but how do you remove the threaded part, so that I can remove the ram cylinder. One is leaking, red fluid see photos. I have the 2 cylinder system with the motor/pump inside the boat (not mounted on the transom) It looks as though the rod goes through the whole system, from one cylinder to the next. I just need to remove one. Is there a tool that helps, or do I punch it out? Thanks. Joel
