Grumpy Bear
- Aug 23, 2014
- 58
br1975 Mercury 500 50hp. See attached pics. A tiny little hose connected from the lower to upper powerhead broke (one pic shows where it broke, the other where it is connected on the lower end). With the motor running, it will only idle at full choke and fuel is spraying from the broken hose. What is it and how do I get that tiny brass tube that connects the hose to the powerhead outta there? Pull it or does it screw out??
