shenktastic
- Aug 27, 2014
- 2
I have an 85 mercury 90hp inline 6 (aka tower of power). It is not running correctly! It will run fine in the beggining, but after it warms up, or we turn it off, or put it neutral, it doesnt want to go again. It will either die, or bog down real low. I have rebuilt all three carbs, replaced fuel line, primer bulb, and fuel pump. I started thinking maybe an electrical issue and a marine mech. Insisted it was the stator. I replaced that with a brand new one. It now starts much easier and runs so smooth! However, it is still bogging down when warmed up. I took the impeller off and its pretty worn out and burnt in some places. Could this be why it boggs? Also, it does squirt out a steady stream of water when running but the water coming out is super hot! Is that normal... please help.... :-(
