modopopcorn
- Jan 18, 2013
- 46
Hi!
I've bought a Mercury 4.5 this weekend and after getting it up and running I noticed that there isn't any water coming out of the peehole.
The first thing I did was to change the water pump and as expected it wasn't pretty... some pieces of the water pump came out when I removed the lower unit and the pump house.
With the new water pump installed and everything put back together and still no water comes out of the peehole.
I took apart the water pump again and found that there was a bit of rubber from the old pump blocking the intake, I took my blowgun and blew in the hose to the peehole, it came air from the feedingtube and I though that it would work now that I've cleaned out the intake.
Nope, still no water from the peehole, from what I can tell there's not blockage in the feedingtube and I can't figure out what to do.
I also hooked up the lower unit to a power drill and the the water pump seems to be working, it's not that much of pressure but I don't know how much RPM I get from the power drill either.
I tried connecting a hand pump to the hose to the peehole and pump water backwards through the system and it seems to be working as it should. I haven't tried from the feedingtube as I don't want to push possible blockage further into the engine.
Video 1
I'm all out of ideas and really need help to solve this problem.
Thanks in advance for any advice that could help me.
Video 1
