It doesn't sound like you have a problem yet. If in doubt, you could replace the impeller now and avoid a problem later. Also open the tstat casing and look for any crud or deposits and then clean out. Also check your water inlet screens for blockage. If you run in salt water you may also need to clean water passages.
