I have an 1988 Mercury 80hp on a pontoon boat. My grandson was driving it when suddenly at about 3000 rpms it makes a "clunking" noise as if the prop has slipped on the hub. I pulled it out of the water and replaced the hub and thrust washer. I then put it back in the water and it still does the same thing. I would greatly appreciate any help any of you can give me on this. The prop is a 14x13p. Also, as far as I could tell the old hub and prop didn't appear to be damaged.
Thanks,
John
Thanks,
John
