If you are adding 12 gal or more, it helps to add a pint of oil to the tank then add 6 gal gasoline, then a pint of oil and then 6 gal of gasoline. This alternating of oil and gas, helps it to mix faster. When the tank gets close to full, add a 1/2 pint oil and 3 gal of gas. That will minimize any miscalculation of how much fuel you need.
