It is normal for that timing to look to be 1/2 tooth off, and it makes a difference, which way it is off, that 1/2 tooth. If it runs better, you should be good to go. If you want to verify timing, remove spark plugs 2-6, stick them into their wires and ground them to the block. Set the throttle to the position where it just touches the carbs, and the carbs are about to open. Install a timing light on the top cylinder. Jumper the starter solenoid (motor in gear, prop removed), to crank the motor. Timing should between 4 and 6 degrees BTDC. Now advance throttle fully. Crank motor and observe timing. Timing should be 21* BTDC. If it differs from that, you probably should get a service manual and reset it.
