We've run this engine for just a few hours each year since purchase. This is the problem we have had this season:
- Starts normally from cold (using choke)
- Pushing in choke when running, the engine runs just for a couple of minutes and then stalls if in idle
- Keeping high revs will keep the engine running for a few minutes more, but as soon as it is returned to idle, it stalls again
- I can't find any adjust on the mixture (seems to be fixed)
- Spark plug is black when removed. I changed it for a new one (correct gap set) and it came out black after just a short running time and had no influence on the stalling
Any thoughts would be much appreciated,
