I just dropped my pontoon in the water. I started it up with earmuffs ahead of the water, and water seemed to be peeing out of the top fine. Now that I'm in the water, it isn't peeing.
Is there any type of checklist to go through ahead of pulling the lower unit and replacing the impeller? I already have it but want to save the hassle if there is an easy fix.
Also I was only able to get the impeller and not any of the gaskets or o rings. Should I wait to get everything or can I get a new impeller in without issue?
Thanks to all!
Thanks to all!
