Bought the above motor last year. Had a mechanic go through it - carb kits, new fuel lines, filters, impeller, new control box, cleaned gas tank. Did not get to run the boat until this season. Having issues starting the boat in low idle/neutral position, need to push up the throttle to get the boat started. Bring the throttle back down, it will stall unless I punch it quickly into gear. Once in gear, all is good. Back down into idle, and stall. Also, on a couple of occasions, the ball has lost pressure.
Not very good with motors, so any suggestions for easy tests or fixes I could try would be appreciated before I spend more money at the mechanic. I know that there is an enricher. When I turn the key, and press it in, I can hear it engage and gas is moving to the motor. Been using high octane gas, marine Stabil with every fill up. A couple of guys suggested that maybe the mechanic did not set the carbs correctly after rebuild, and then someone else suggested idle timing due to new control box. Any thoughts appreciated.
