sumyunguyz
- May 29, 2012
- 5
I'm at my wits end on this problem I'm having with my 2000 75 hp Merc (S/N OT160329) on an 18ft. pontoon boat. I've search the forums and can't seem to find anything that's similar to this problem.
Engine starts and idles fine. Seems to start missing on one cylinder around 3500 rpm. As I gradually increase throttle between 4000-4400 rpm the cylinder seems to start trying to fire as the rpm continually increases then decreases. Prior to this problem I was running around 5100 rpm wot. Now it's running around 4600 wot.
I've pulled and cleaned all the carbs, (found some trash in top carb hoping that was it) OEM fuel pump was replaced back in spring. No restrictions or leaks in fuel lines or fuel tank. Have external Racor filter separator installed that has fresh filter in it. Only running non-ethanol fuel in it. New spark plugs also.
It was running fine up until a couple of weeks ago. I keep thinking it's a fuel problem causing the surging but can't seem to find anything.
Any feedback or ideas is appreciated!
