I have an 1978 inline 6 Mercury 90hp on a 16' bass boat. Just installed a tachometer, water pressure gauge, and water pump and took it out the other day. Water pressure at WOT is about 8-10 psi and about 2 psi at idle, which seems good. Engine has good even compression, but at WOT, the tach only says 4500 rpm and I barely hit 40mph by myself with the motor trimmed up a good bit. With other two people on board, I'm lucky to get 36 mph. My question is, what rpm is this engine rated for and what prop should I get to increase the speed? I currently have a 19" pitch prop and it's not stainless. Poking around on the forums, most people with a 90hp and a bass boat my size seem to get 45-50mph. Is something wrong with my setup or are people just over exaggerating?
