The engine runs, but poorly. The other 2 cylinders show 115psi compression. There is a distinct knock in the motor. My thoughts are that it is probably the rod bearing. What do you guys think? Do I take the head or the crankcase cover off first to investigate? If the rod bearing is bad, would I not still get some compression reading?
