Hi everyone....could use some advise I have a 1997 Mercury 75 hp outboard with oil injection....I salvaged this off an aluminum Tracker boat....I pulled the complete harness.....When I start I get an audible chip......idol around nothing more...but when I throttle up the chirping persists... It's coming from a little red sensor that is under the dash wired to the ignition then to the engine...My question
1) is this a low oil alarm? ( I was trying to run the oil down so I could use Synthetic so its 1/4 full at this point) at what level does the alarm sound?
2) I traced the wire tan/blue/straight to the engine it goes under some modules and the a tan /blue/twist wire goes around the engine and into the head?
I'm guessing knock sensor?
The engine runs prefect...puffing a little smoke as it should...peeing strong...
Can someone please advise. Thanks
