chadpcb
- Jul 24, 2010
- 119
I will try to discribed the issues to the best i can. I have never owned a mariner before so I do not know if the sounds should be there or not.
Issue #1
There is a top end knock. I have used a scope in order to try and locate it but I can not. It seems to be coming from under the fly wheel. I have scoped every cylinder thinking it is a bearing or a bolt in a piston arm but it is not coming from any of the cylinders that I can tell. It also seems like when you when you apply throttle it doesn't get any louder and seems to go away.
Issue #2
I throttled up on the back side of a wave and the engine just reved up. Pulled back to nuetral and back into gear again and the engine responded as normal.
Any ideas and any information would be greatly appreciated....
Thanks
Issue #1
Issue #2
Thanks
