Hello, I have a 1978 Mercury that I bought from the original owner after sitting for a few years. Had it for a few years and it never has run quite right. Rebuilt carbs, fuel pump, some wires, replaced stator, rectifier,trigger, coils, and check switch box with know good one. Tried gas tank and primer bulb from my other good running boat (1982 50H Merc) I've had various problems, but now it seem to not want to idle in neutral, and the RPM's aren't steady when I give it gas. When I spray some gas in the upper carb it revs up (bad, right?) but the lower carb doesn't do anything when I spray gas in it. I checked out the upper carb again and it looks clean and the float is set correctly. Out of process of elimination, I would like to check the reeds. Can I at least inspect the reads by taking the crank cover off? Do I need to pull the crank out to replace them, or can I sneak the read blocks out once the cover is off? The Seloc manual says complete overhaul is needed, but I really don't want to do that if I don't need to.
Thanks for the help.
