jeff surles
- Jul 6, 2014
- 7
the problem im having is that the motor will not idle so i checked vst psi fuel rail psi compression spark at 7/16" gap air pressure replaced vst filter replaced plugs and also replaced fuel line.well none of this helped.the last time i took it out to the lake i was coming in to dock and the engine wouldnt even come up to speed and seemed to be missing...note all the above tested past the manufacturer specs...i also removed the air compressor and checked the reeds and they were fine
DOES ANYONE KNOW WHAT ELSE I COULD TRY? ANY HELP WOULD BE APPRECIATED GUYS AND THANKS
