Nathan Bond
- Jun 28, 2014
- 45
Having some intermittent starter issues with my boat.
When the engine is cold, the starter will either a) crank normally or b) very, very slowly crank.
No way to determine which it will do, turn it over 10 times and it's fairly random which will happen.
Sometimes, it was start cranking slowly, then after 5 or 6 slow cranks, speed up to normal.
Once the engine is warm/hot, it's almost always slow crank.
I've tried it with 4 known good batteries, 2 of which are brand new.
I went through some of the troubleshooting steps in the FAQ, and here are the results/measurements.
Battery before cranking: 12.9 volts
When starter cranks normally:
Battery voltage while cranking: 11.5 v
Starter Positive Terminal/Engine Ground: 10.2 v
Solenoid Input/Engine Ground: 10.2
When slow cranking:
Battery voltage while cranking: 10.5 v
Starter Positive Terminal/Engine Ground: 8.4 v
Solenoid Input/Engine Ground: 8.v
After very little cranking overall (maybe 4 to 5, 5-10 second cranks to take measurements), the starter will warm up and and it's always a slow crank after that.
In fact, with both fully charged batteries on (I have a 2 battery switch), it will slow crank with both batteries in circuit, once the starter gets warm.
Time to replace the starter? I would think it were corroded cables, it wouldn't crank normally at all.
When slow cranking:
