I have a 94 Mercury 175 carb model outboard. The powerhead was just completely rebuilt, I sucked the #1 ring. The engine runs great high speed and low. After a long idle through the No Wake zone, when I pull it back to neutral it will stall and it will be hard to start. After some cranking it will start and smoke us out for 15 seconds. It then clears up and runs fine again. Of course the stalling is when you try to dock it with everyone lookin. My double oil should be gone by now. Any ideas why it is loading up with oil? The idle may be set high. Any chance the idle is set too high causing the oild ratio to drop to 50:1 instead of the normal 100:1. I haven't got the tach working properly since the rebuild. Any tips on test the tach? How would I hookup my tester with a tach to test the rpms? What pins should I used? Will it work? Or does it need the Mercury tach?
Any help would be appricated. Oh yea the oil injection is working, it wasn't but now it is.
