I just bought a pontoon that was sitting a while - trying to "make sure" of the year before I order parts.
There is a mercury 500 thunderbolt outboard
the serial # is 2628575 located on the transom bracket - On the old merc website that co-relates with my engine being a 1969
I recently got the engine started but its not spitting out water so I need a new impeller - also I went to drain the lower unit and nothing came out - no gear lube or water - nothing...
I filled up the lower unit and gear lube started dripping out of the propeller so I also need a prop seal... it dripped out for a alittle bit but stopped - going to replace it anyways
I am trying to find out the year to "make sure" before I start looking for parts - I can not located the freeze plug core plug either.
any help would be greatly appreciated.
