1976 Mercury 1150 with power tilt and trim
funboy30189
Hey guys, I just bought a new to me starcraft with this motor on the back. I feel like a total rookie but im trying to remove the whole unit off the transom. I see 4 what I think are hydraulic lines and an electrical cord. I understand disconnect the lines but how do you remove the electrical cable?
thanks in advanced
procraftguy
Ok should unplug from side unless its been rewired without like alot of those as the plugs go bad post pics alot can be done to a motor in 40 years lol
procraftguy
Also if you are talking about cord from trim its for limit switch follow it to pump there are two wires and each have a plug just pull apart to remove without removing pump but once again on mine there were bad and spliced years ago
