Orion Nebula
- May 15, 2014
- 4
My 50 HP Mercury will only run at half throttle. I have replaced the powerpack, coils and trigger but am still only getting half throttle. I tested the voltage on my powerpack and am getting 295 volts from the stator side and around 150 from the coil side. The compression on all four cylinders is around 130 psi. I am getting spark on all four cylinders. Any ideas on what the problem could be?
