How do you get the throttle and shift cables off at the motor? I see the two things you flip to release the stops. But it looks like the throttle cable you have to get at from the side and there is no access. Does that lower cowling come off or if it is loose do you have enough room to get at it? The shift cable looks like you should be able to get off from the top. Any help is greatly appreciated. Thank you.
