Hi. I dropped the lower unit on my Mariner 40hp ML engine, serial number 6E9 L 359629 to change the water pump impeller.
Whilst waiting for the parts to turn up I changed the gear housing oil. The lower unit has been sitting for a couple of days upright, separated from the rest of the engine and I have noticed the clean gear oil is leaking around the prop.
I removed the prop and the prop shaft seals are dry, the oil is coming out through the exhaust not the seal carrier.
Any suggestions where the oil is leaking from?
The only thing I can think of is the gear shifter linkage seals, but according to the diagrams there is no seal only a sleeve.
Darryl
Darryl
