Re: 1986 mariner 175 hp oil injected system
I have a 90 with the built in oil tank and oil pump. I merely pulled the pump, removed the drive gear, checked for any loose associated bushings or washers and reinstalled the pump. Took all of 10 minutes. I drew a line on my oil tank at the (then) current oil level to periodically check to ensure I was no longer using any oil from the tank.....after a couple of years, I'm not.
On the larger engine you may have 2 tanks, one onboard and the other boat mounted but I don't see that making any difference. I would assume you would have a similar oil pump with a similar drive gear which you just pull out to remove. I would also assume that since a low oil condition results in a ground being sent to the alarm, if you have an accessible connector on the tank, just pull it to ensure the circuit remains in the open state with no ground for the alarm. I left my alarm intact and have had no problems.
HTH,
Mark
