frankrizzo
- May 5, 2014
- 21
I am at a loss. I received a 90hp Mercury mounted it to the boat hooked it all up fired right up, tilt/trim work great, but when i try to put it in reverse it will not go into it, im not sure it is even going into neutral. I unhooked the throttle cable and the shifter cable and tried manually shifting with no luck. i can move the shifter mechanism on the motor just fine but it seems to be doing nothing at all. The previous owner passed away so I cant ask if they had problems beforehand. Also when i reassembled during my initial attempts to start the motor i realized that the cables were not hooked up yet, could that have damaged the fwd reverse neutral gears? I ordered a new waterpump kit so i will be removing the lower end shortly but not sure what i am looking for to repair.
Also is their any local stores that would sell the manual or is this something i have to purchase online?
