I have a 94 225 Mecury carbed. The timing is not advancing between 1000 RPM's and 2300 RPM's. Motor starts and idles fine. When you start to give it gas is will bog out popping and spitting. I have changed the ECU, TPS and the Stator. Even rebuilt the carbs and reset the rack. Any suggestions on what could cause this problem. I have had it at couple of mechanic shops with no sucsess. Any advise will appreciated. I'm about to give up on this one.
