mercuryman80
- Oct 25, 2012
- 30
I have changed plug wires using high tension copper core wires , replaced both coil and sparkplug terminal ends.
The problem is I have arcing wires everywere the # 4 plug wire is a 22inch blue line in the dark arcing around coil packs arcing out of cylinders 1 2 3 also but not as bad as 4 I have blue arc over all 4 spark plugs between the boot and block on the insulation portion of the plug I'm suspecting a ground and thoughts would be greatly appriciated !
