Ok, I noticed my seal/gasket that goes around/behind the oil plug has dry-rot, so I order a new one (Part# 826276). They send me two, so I'm thinking I have a spare. :whoo:
I need to change oil, so now would be a good time to replace this seal. The old seal comes out in a couple of pieces, and I place the new seal around the oil plug and stuff the seal under the lip like the old seal. This can be done for only 3/4 of the hole as the upper 1/4 is solid. In doing so the seal tears. :facepalm:
So before I try again, I'm wondering if anyone has any advice on replacing this seal so I don't mess it up again. Just to make sure I install it correctly.
Help!
-Brian
I have attached a photo of the ripped seal 'installed'.
Help!
-Brian
