Messing About
- Feb 10, 2011
- 23
I've owned the boat/motor for 6 months and run it several times every month.
Used to run 37-39 MPH at 5500 RPM at WOT.
Recently started have a much weaker hole shot, although can still plane out with me alone aboard. With 2 of us, no.
Top speed is now only 25 and RPM sounds/feels noticeably weaker, maybe about 3000?
Faria tach used to work intermittently but now won't register at all.
Only recent issue before this was getting stuck on the sand flats and resulting in a slow to peeing motor.
It did finally start to pee and I made it home. I did a new complete water pump kit, including gear case cover. Old one was pretty crusted with sand in the crevices. I changed gear oil and old looked dark but good. I changed both fuel filters and found a double pin hole in the inline filter tube, before the filter. Not sure if I did it during the change or it was existing, but nonetheless, I changed the tubing.
Did a sea trial and the performance is still the same poor power. Pee hole on muffs starts faster, is stronger but sputters.
I researched repair records from prior owner and found a shop repair ticket from 2 years ago that read, "slight knock in engine, intermittent alarm. Found main jets in carbs in wrong positions. Put main jets in their proper place. Replaced spark plugs and primer bulb. Knock is 98% gone." For the record, I don't notice any knock.
Any ideas as to my loss in power? Remember this is the 2+2 cylinder. I have a comp tester but haven't gone there yet.
It starts, idles and shifts just as fine as ever. Thanks in advance for the courtesy of expert replies.
