I have been helping my son restore a 1990 Aluminum Bass Boat and am down to the final throws. Issue we are having is that it is very hard to shift into reverse.
I have isolated it to the lower unit, I believe. With the lower unit off of the boat, it shifts equally well into forward and into reverse, but with the lower unit installed, it is extremely stiff (like have to raise up out of the seat and apply body weight to get it into gear).
However, if I shift it at the lower unit, I cannot tell a difference in shifting it into forward or reverse (difficulty wise).
But, the prop when in gear, either forward or revers, will ratchet one way and is engaged the other, but spins freely in neutral. Should it ratchet whether it is in forward or reverse? I am thinking it should only ratchet when in one or the other, but not both?
Also, is it possible that I need to check cable adjustment? I put new cables on it, matched to the same setup, length, and adjustment as what I took off while we were in the process of restoring everything else since they are 24 years old, but no idea if they were correct to begin with.
Any help determining where I need to do more trouble shooting, or what I need to look at is appreciated.
Also SN of motor is 0D041784
Any help or guidance here is appreciated.
