Re: Reused a used head gasket?
The used gasket will seal enough you will be able to start the motor, and it will run.
HOWEVER, Cyl pressure during combustion varies with the amount of load on the motor.
While your used gasket may seal perfectly at an idle, and at very small throttle in gear, All bets are OFF once that throttle opens up.
Cyl pressure during combustion can exceed 2000 psi at WOT.
WHEN, and notice I said when, not if, WHEN the head gaskets leaks while underway, combustion gases leak into the cooling system , displacing cooling water.
And what happens to a motor running WOT with little to no cooling?
It turns into a very expensive boat anchor.
$30 for a new head gasket is very cheap insurance against ruining your motor.
It isn't worth the risk.
