halmc
- Feb 27, 2008
- 231
Engine in regular use; owner hops in boat, battery flat; charges battery, engine won't start; voltage regulator fried (burned and stuff oozing out) engine spins over fine but no spark at any of its four cylinders.
So the VR is obviously fried. And the engine has no spark. The only link I see between the two observations is the keyed switch in the remote control that might have failed such that the ignition remained on and such that the black and yellow 'kill' wire is getting a ground.
I'm taking my multimeter to the boat this AM to see whether the 'kill wire" is getting grounded somewhere.
I'm very skeptical that an 'on' ignition switch would fry the voltage regulator. (anyone agree?) A failed rectifier might. Is the rectifier a separate item on the engine described above, or is it integral with the VR?
Lastly, after examination of the wiring diagram, I'm at a loss to see any other link between the spark and the VR. Anyone else see one?
I'm very reluctant to replace the VR without knowing what made it fail. Any comments welcome.
