Serial # 0G239008
Water flow is delayed at start and poor pressure. I have to bring up the RPM to get the water to start flowing. Once flowing it stays pumping with poor pressure. Water temp is pretty warm coming out as it steams even on a hot day. I am pretty sure this motor does not have a thermostat. I had a problem about five years ago and changed the impeller that looked perfect and found I had a nest of some sort in the discharge tube between the motor and the pee hole. Started having issues again last year and changed the impeller that was perfect again. Checked the hose and it was clear. Sent air through the pee hole back and it sounded clear. I was told to check and make sure the water tube from the pump to the motor was in the bottom of the and it is. I purchased a Seloc book but have no idea what to try next. Any help would be appreciated by my sons and I.
