I have a 88 mercury black max xr4 150 runs great idling but only runs 4000 Rpms at wot it has good compression and good spark just can't figure out if the timing is off or something
Is this something that started suddenly ?-----Could be a reed valve problem.----Blockage in a carburetor.---Flooding carburetor.----Fuel pump problem.---Sort this out before running it anymore.
Idk If this has anything to do with it but the primer bulb doesn't stay tight and when you trim it up all the gas runs out and notice gas in the test tank
Someone told me I wasn't propped right it's got a 24p laser 2 on it they said run a 22 or 23 pitch prop will that bring my Rpms up and get me speed or make me lose speed
