kustomkolors
- Apr 15, 2014
- 5
I have a 02 mercury bigfoot 60 h.p. efi. Serial number ot505062 . Wants to stall and stutter when throttling up. And between gears shifts. If I throttle lightly it will be fine. Idles good and runs good at higher rpms.have changes plugs and both fuel filters. Primer bulb. Checked fuel pressure at high pressure pump and its 42psi. Other than sea foam is there anybody that has an idea? Thanks I hope once again.
