fishon1213
- Aug 10, 2009
- 80
I have a 1978 Mercury 200 20hp s/n 4821964. I am only getting spark to the top cylinder. I swapped the plugs and wires and got the same result. I pulled the flywheel to investigate and found the wires coming from the stator to the rectifier had cracked and missing insulation. I replaced those wires and still the same result. But then I was thinking that the function of the stator should not effect the spark. Is that correct? Unfortunately, this motor was submerged in the river. Not by me, lol. I cleaned up under the flywheel with electrical cleaner. I do have a multimeter but am not well versed in using one. So what do I look at next to determine why there is no spark to the bottom cylinder?
