Re: How do I change the upper steering/shock mount- 1982 50HP
Your s/n comes up as:
MERCURY - ( 50 H.P. (1983 ))
Serial No: 06276686 Model No: 1050623
Parts and Service Bulletin list for s/n 06276686:
Search Results - Crowley Marine
By head gasket, I presume that you mean the water jacket cover gasket, seen as item 10 under END CAPS AND EXHAUST COVER
If you are talking about play at item 13 under SWIVEL BRACKET AND REVERSE LOCK, this is common and if you were to take it apart you would find that grease seals, item 2 will be scrap and need to be replaced.
As for the washers and shims, items 12/8:
47606 Washer Swivel PIN Mercury 500 50 HP SN 25168XX | eBay
25176 Washer Swivel PIN TO Bottom Yoke 06 1972 Mercury 402 40HP SN 38628XX | eBay
The retaining ring is available but Iboats won't let us post the competitions sites. Take the P/N and goggle it.
You are also apt to find severe corrosion between the splines of the yoke, item 15 and the swivel pin, item 5. You can inspect the lower mounts by removing the covers but depending on how they look, you might find that power head removal is the least of your problems.
Gerry
