I have a question on my 1987 Mercury 'Classic Fifty', 45 HP outboard motor. It currently has the 'autoblend', and I am going to remove it and mix the gas. The gas hose runs from the gas tank, to the autoblend, then to the motor (with the bulb in this line). I know I can just remove the autoblend and connect directly to the motor, but what about that small electrical connection that connected into the autoblend and runs into the motor? Can I just leave it, or should I follow it into the motor and remove it? Will I have issues with the alarm located on the ignition? Thanks for any help.
