Hi, I have a 1996 Mercury 75hp Outboard SN# OG302623 that has loss of power. 1500.00, 2 mechanics and same problem. I have replaced the ignition, stator, trigger, all 3 coil packs, plugs, and wires. Carbs have been cleaned and prop replaced. It used to run great after new plugs for 5-10 minutes, then the plugs would foul and would lose power. Now I can't get acceleration and only runs 10-11 MPH, versus the 33-35 before. Any suggestions or what I can test myself? Last mechanic said compression and spark looked good.
