Okay, I checked compression avg. #1 cyl=135, #2 cyl=140. good spark on both cylinders, gas was coming out the front inlet of the carb. so I removed the carb to clean it.
Now I re-installed the carb, tried to crank it and I have no spark, compression is still the same, and I still have gas coming out of the front inlet of the carb.
I have checked the stop switch and it is working fine. What could have happened, I'm so cunfused now.
