gwgautney
- Aug 28, 2013
- 283
I'm researching this for my dad. He has a 2004 Mercury 50. it cranks and idles fine and will run fine at lower rpms fine. when he gives it throttle and runs at higher speeds it will run at that speed for a few minutes and then drop back down as if you were throttling it back down. if you hit the choke it will pick back up and start speeding back up. also if you let it sit for alittle while and crank back up it will run fine for a few minutes and then do it again. Its almost like the fuel is being restricted its not likes its bogging or anything. I don't have sn or model number right now but I will add it later
thanks
thanks
