sqlightning
- Aug 31, 2012
- 8
I've got an 84 Mercury 115hp on my boat and the tach does not work. I put a new tach (faria) on it a few weeks back and it worked for a second then stopped working and hasn't worked since. I think i had it on the wrong setting. After I put it on the right setting (12 pole) it is still not working. I check out the rectifier per the seloc manual and it tested bad, so i replaced it with a sierra part. when i went to test it, i just bumped the engine over (not actually started it) and the tach would not move. is it possible having the wrong setting on the tach damaged both the tach and the rectifier? when i hooked it back up, i attached the gray signal wire to each of the yellow wires going to the rectifier and still nothing. does the engine have to actually run to see the tach move, or can it just be bumped over? what else do i need to look at on this?
