Have 1967 650 Mercury. Just got running went out to water. Only get about 8 MPH at WOT. Noticed that the linkage needs some adjustment to get the dist. to rotate to WOT stop, BUT notice that the plate that moves the carbs only open them about 1/2 way. There is play before the plate contacts the carb linkage. That is as the throttle is advanced the dist. moves some amount before starting to contact carb linkage. Looks like I can adjust that plate, but not sure if I should. Someone put a red mark indicating where it is now? Any pics would help Thanks
