I just changed the water pump in my 82 50 hp (4 cylinder). The parts diagram shows more parts than are actually in the kit. I'm mainly concerned about the connection point between the output port on the pump, to the pipe that pumps into the engine. The parts diagram shows a nylon seal and a rubber seal, in between the pump and the pipe leading to the engine. However the kit doesn't have anything that fits in that position.
So my question is whether the new kits are different than the parts catalog due to design changes etc. It does pump plenty of water out the **** tube, but it's also leaking water from the area where the lower unit is bolted to the engine. It's also got plenty of water pumping out of the two plastic screens/vents at the trailing edge of the lower unit- above the propeller.
I'm wondering if there's supposed to be a perfect seal where the metal pipe plugs into the water pump, or if it's designed to spray a certain amount of water into that whole section of the lower unit.
Anyone who knows what I'm talking about, please help. I have plans this weekend with the boat for my birthday.
THANKS!!
JOE
THANKS!!
JOE
